Hi All,
Hopefully I'm posting this in the correct place. First off I'm looking to put together a system to lower our monthly bill and eventually expand on it. The system needs to be grid assisted but with no net metering. I would also like to have backup power when the grid is down for the essentials. Our budget will be around $5k to start.
Currently thinking of using an all-in-one inverter, EG4 48v 100AH battery, and use the rest of the budget to buy used solar panels. Our kwh usage for the past year was 10,520KWH, Average 880KWH, High 910KWH, Low 680KWH. Im in PR so it's always sunny and hot. According to an online solar system calculator we get avg of 5.53hrs sun hours. We dont have to worry about any permits, labor will be done by me.
What inverter would you suggest I use and can that battery be enough to run say 2 fans, refrigerator overnight? Is this even a good idea? Can all-in-one inverters be used as I need? Given our energy use, what system would you suggest?
Thanks in advance
Thanks in advance
