Radix
I am in the final step of installing the components on the wall. Found an Electrician who is familiar with Solar but not a solar installer, so my concern is he will install as he figures will work. I am more concerned now with how it will work to have the PV system off and still run on grid until approved.
I was told I needed a sub panel in case Grid goes down, otherwise Solark will not run either, but as I understand, the current main panel would be emptied of all breakers and used in subpanel, so subpanel is obsoleted.
The Main Panel is a combo Meter/main Panel, to avoid running a secondary panel, the thought is run from Meter -> AC Disconnect ->Solark15K -> back to main breaker panel. Electrician said this will work, asking a buddy of his that has done solar installs before.
My concern is will I be without power until city and PGE approves because panel is tied only to Solark, or can the Solark be on, but just Panels/ PV generation turned off/ disconnected via the Solark Controller?
I am still confused on the subpanel requirement to keep running in a Grid down scenario, but concerned with my approach will leave me powerless until city and PGE approves to turn on. Look through youtube videos but all really only talk of adding panel to power their garage not tied in as a whole house source.
Electrician is supposed to be available next weekend or following, so I have a week or two to source another panel if needed.
Id appreciate any help or knowledge so I am not without power for taking the DIY route.
Thanks
Thanks
