Roswell Bob
I have cobbled up a short Mathcad file which calculates inverter losses and heatsink requirements for a 5kW inverter at 10kHz. The transistors will do 200% continuous given a good heatsink, This file could be used to develop both low and high frequency designs. I expect that this bridge could replace blown out guts in a commercial inverter. I will use in a 48v high frequency design. I will present that paper (DC-DC converter) design soon. I will do thermal simulations next and present the thermal contours. I have chosen Ixys fets for these calculations. If anyone would like me to run an IGBT or a SiC mosfet just give me part number. I will put together a Magnus Opus file which contains everything that a boss or client would ask for when a design is complete. Maybe we build one some day and see it it works I have Mcad, RTL, and HTML files which will not upload. I will try to convert to pdf and upload. If anybody want the other format just msg me.
