meetyg
- Jun 4, 2021
- 1,071
Hi.
I'm building a DIY Lifepo4 battery in a battery box, like this:
I will be putting a DC breaker on the top of the battery box, mainly as a disconnect switch, so that when doing maintenance or disconnecting the battery, the terminals won't have voltage (positive side).
My question is, should the BMS positive be also connected to this switch, so that BMS won't have voltage either (just for additional safety) ?
What happens when you disconnect the positive lead of the JBD BMS ?
Is it a good idea or will it just confuse the BMS when powering off and then on?
Thanks.
Thanks.
