Mike Jordan
- Jun 15, 2020
- 414
Has anyone DIYed an MPPT solar charge controller?
I have died a couple of SCC's, yes!Has anyone DIYed an MPPT solar charge controller?
If you are sure that your SCC is a real MPPT, go for it in confidence.I'm a very basic meat and potatoes kinda guy. I'll leave circuit manipulation to the learned.
But seriously, what could go wrong with using an SCC powered by a 24V battery to charge a 12V battery. It won't be able to keep up to a 1000 watt draw, but it should be able to replace approx. 500 watts (26X20).
Good to know!!If you are sure that your SCC is a real MPPT, go for it in confidence.
If the SCC is just pretending to be, but is really PWM electronics inside, you will get very high current pulses between your two batteries.
Enjoy the magic blue smoke...
You can separate the good from the fake with a multimeter:
If, without any connection, the minus of solar panel and battery are connected (< 1 Ohm) together, the chances are great that you have got a real MPPT circuit.
If the the minus of solar panel and battery are not connected or > 100 Ohm, I am ready to bet, that it is a PWM inside, whatever is written on the case...
This test assumes that the PWM controller is switching on the negative side. There are PWM controllers that switch on the high side. These will pass your test & come off as MPPT's.If you are sure that your SCC is a real MPPT, go for it in confidence.
I found that github a couple of weeks ago, and I recognize your screen name from the discord over there. That build looks exactly like what I am looking for. But every time I ask a question, you guys go on 47 tangents that are all above my pay grade. I am hoping I can discern some direction out of the 47 tangents. But I am not sure I will ever make any progress.I have died a couple of SCC's, yes!
I am currently in the process of conceiving and debugging a family of WiFi controlled MPPT solar charge controllers by injecting a signal into the selection of buck converters, to cope especially with the requirements of low power needs for instrumentation projects.
Tim at Github has done it in power ranges up to 500W based on a DROK power supply.
But in the range over 20A you are probably better off buying the regular stuff.
We are in the middle of brewing that beer. That goes not without turmoil... Wait for a couple of weeks more and enjoy your fresh tapped draft, once the paperwork is done.But every time I ask a question, you guys go on 47 tangents that are all above my pay grade.
Way above my pay grade as well...but very intriguing. My keg is right beside me ?I found that github a couple of weeks ago, and I recognize your screen name from the discord over there. That build looks exactly like what I am looking for. But every time I ask a question, you guys go on 47 tangents that are all above my pay grade. I am hoping I can discern some direction out of the 47 tangents. But I am not sure I will ever make any progress.
I was hoping to find some folks as intelligent as you guys, that could also speak in non-geek. Or maybe find a translator from the geek to non-geek
What would really be awesomeness is if @Will Prowse did a build video for a DIY MPPT controller. That would fit quite perfectly into his channel. And he is a GREAT translator of geek to non-geek
As a big fun of OSPController - it was powering my off-grid shed and shallow well water pump last summer - would absolutely love to see it featured on @Will Prowse channel. Meanwhile, maybe Tim's video makes life little easier for casual brewers OSP Hardware buildWhat would really be awesomeness is if @Will Prowse did a build video for a DIY MPPT controller. That would fit quite perfectly into his channel. And he is a GREAT translator of geek to non-geek
I found these guys a while back. I was pretty excited. But they operate on a level above my pay grade. There was so much "mine is bigger than yours" going on, I was lost. They finally got things a little better reeled in, so I got my mind wrapped around the hardware. But the software programing has me lost. I am waiting on Tim's software video, before I try to jump inAs a big fun of OSPController - it was powering my off-grid shed and shallow well water pump last summer - would absolutely love to see it featured on @Will Prowse channel. Meanwhile, maybe Tim's video makes life little easier for casual brewers OSP Hardware build
Tim's solution isn't that expensive?But they operate on a level above my pay grade.
Above my "Paygrade" is a euphemism for above my skill level. After getting Tim to reword some of the verbiage and flow of the hardware pages, to make sense to a wannabe geek, as opposed to a real geek I got that now. I am waiting on the software update vid, which I don't get. But with enough waiting, my original use project needs to move forward in another direction. But still interested in figuring it out for future useTim's solution isn't that expensive?
Where is your pain limit and how much power do you need to control?
I was looking to start with just a DIY portable solar gen, so probably not more than 200 watts . But hardware is the easy part. Thats not my issuehow much power do you need to control?
Hey, @Horsefly, come over to OSP discord and we will get you going! Depending on what setup you have, maybe all you need is to add DPS5005 to your esp32 and off you goJust stumbled upon this thread. I have two spare nodemcu ESP32s sitting around looking for something to do. Even though that component is one of the cheapest in the github project, I'm tempted to do this!
@Mike Jordan, may I ask you to check the direct message on discord? Maybe I can help you to deal with the SW while Tim is working on video. (I think) I speak a little non-geek :DI was looking to start with just a DIY portable solar gen, so probably not more than 200 watts . But hardware is the easy part. Thats not my issue
Then Soft Power may be your friend.I was looking to start with just a DIY portable solar gen, so probably not more than 200 watts . But hardware is the easy part. Thats not my issue
