lykkechristian
- Dec 12, 2021
- 13
Hello to everybody!
I am Christian from Denmark, currently traveling the pan american highway from USA to Chile!
Since then i have been amazed about relying on the sun driving my Campertruck.
Now i am trying to calculate if possible and what i need to run everything solar at home. Denmark does have long periods of bad cloudy weather.
I want to run following. So here is my minimum requirements.
1. 9kw heatpump (Air to water) - This i have to install, so am unsure about kwh a year consumption. but roughly 6.000 kwh.
2. General appliances (Normally i use 3.000 kwh a year.
I am thinking of installing enough for 10 kwh consumption to be sure.
My thinking is.
Panels:
12kwp panels. (32 panels of 380 watt) . = Estimated 7.000 usd
Denmark gets around 1000 w/m2 and generally 1.000 kwh per 1 kwp panels.
So system should generate around 12.000 kwh hours.
Inverter:
Growatt - (SPH10000TL3 BH) - PV max 13kw, AC output 10kw. (Battery voltage 100-550 volt). = Estimated: 2.000 usd
or
Sungrow - (SH10RT) - PV max 15kw, AC output 10kw. (Battery voltage 150-600 volt). = Estimated: 2,000 usd
Batteries:
Batteries: 4 x 48v 100 ah, Lifepower 4 battery by EG4. = Estimated: 7.000 usd
I would need minimum 4 in series to get above the battery range for the inverters. 48v x 4 = 192 Volts.
Total battery capacity would be: 19,2 kwh at 48v (x4) towards. 20,48 kwh at 51,2v (x4)
Total:
Estimated 16.000 usd.
I am aware that i need cable, meters, mounting racks, fusing etc.
Questions:
1. Does this sound correct or am i missing something and/or something i need to consider?
2. Would it be better to go with smaller inverters (48v) and then have multiple to run more wattage?
3. As i see it i might need much more PV, because of lack of sun in winters (Which is also where most power will be used for heating)
4. I am not sure how to calculate if i would have enough battery, since consumption would be 10.000kwh / 365 = 27 kwh a day.
5. Anybody know i it can be setup to heat only extra during the day with sun (even at 50% sun, would be enough to heat - since the heater also doesnt go all the time, but periodically)
Please come with input etc.
And thanks in advance.
Christian
My thinking is.
Panels:
Inverter:
or
Batteries:
Total:
Questions:
Christian
