Hi all... need a sanity check on my system planning at a component level. i'm in Michigan, so definitely have to contend with winter temps.
all-in-one inverter/mppt:
Growatt spf-3000tl-lvm-24p
max PV voc=145
PV input= 30-115
panels:
10x 200w (likely RichSolar at this point) 12v = 20.4voc/20.4vmp/9.8a for "2000watts" total.... which is right at the "2000 watt" PV input limit on the growatt... check good
I was originally going for a 48v system, but I have a partial shading issue on one panel (d'oh!). so, with that, I am needing to drop array voltage to have 5 panels in series on two parallel strings so I can at least get 1kw on one string.
here's my basic math:
5 panels @ 24.3voc= 121.5voc which is less than the 145voc limit on the growatt....check good
so.... need help with winter temps. I recall reading somewhere on here needing to account for a winter temperature "spike", and suggesting a calculation factor of 1.2 for planning.
121.5 * 1.2 temp coefficient = 145.8voc which is right at the 145voc on the growatt... yikes?... not good? << help here please
5 panels @ 20.4v operating= 102v which is in range 30-115v for the growatt....check good
two 5 panel series strings is 9.8a per string * 2 strings = 19.6amps... plenty safe for typical wiring/breakers/disconnects. nothing fancy needed.
for reference, this system is being sized to support two freezers and a refrigerator estimated at 4166watts/day. at a solar factor of 4.1hours per day here in Michigan, i should be generating approx 6500watts per day at 80% efficiency. i'll have 200ah at 24v for ~5kwh of storage, which is enough for 24hours of no PV input. not ideal, but I plan to expand the battery bank to 400ah as funds allow.
max PV voc=145
PV input= 30-115
panels:
