TexasAmerica777
Hello, This is my first post and the forum. Been reading a lot of threads for awhile. I am gathering information on a DIY grid tie system. I live in rural Johnson County Texas and already confirmed there are no permits, just need my co-op to sign off on the plans. Details on my system (thus far) is below please let me know your thoughts or any recommendations.
Inverter - Sol Ark -15K
Panels - 36x Aptos 550W bifacial panels. 2 strings per MPPT (6 panels wired in series, then those 2 sets of 6 panels wired in parrel)
Racking - Iron Ridge roof mount, XR-10 rails with flash foot 2. I do have some panels that will go on a metal roof with PBR panel and will use S5 brackets
Battery - Discover Helios 16KWH
I will be installing a 200 amp fusible disconnect right after the meter, into a J box where I will do a line side tap with Polaris multi tap connectors. One line goes into grid connections on inverter and the other line will go into a 200 amp bypass switch which will then feed my houses panel. I am planning on following the Bypass diagram in Sol Ark's manual. I believe it is diagram 7. My goal is to mount and hook up all the solar panels, run the PV wire through conduit down through my attic to inverter and mount the disconnect, bypass and J box with 2.5" conduit connecting it all. I have already lined up an electrician (Energize with Sunrise based in Burleson, TX) to do the final hookup.
I also have a call later today with Chris from Practical Preppers (Engineer 775) to talk through some details and questions I have regarding over paneling.
