Yeah, we are lucky. I have co-workers in DFW and they are over $.20I'm right about $.14/kWh, with a small negative offset at times. Guess I'm kinda lucky.
That actually worked for me, a factory reset. Previously I had tried power cycling (reset) but that didn't work.Maybe it’s like a windows computer and we need to restart it occasionally….![]()
And Yet it appears they Literally threatened a member here with doing EXACTLY that when the member commented on buying a DEYE unit on a YT SolArk install comment section in 2021Sol-Ark didn't, and you know that.
I see someone said it, not Sol-Ark saying it. Maybe they did say it, can't say. Means nothing. There is absolutely nothing that points to Sol-Ark being the company who bricked the inverters. If someone can show me differently, I will change my opinion.And Yet it appears they Literally threatened a member here with doing EXACTLY that when the member commented on buying a DEYE unit on a YT SolArk install comment section in 2021
page 106
Below links read,
I still think the new 18K Sol Ark will be a Great unit for those wanting , more output power, and upgraded MPPT's , but I am going with lesss expensive multiple Inverters route myself.
Caulking. Just decide if you want paintable or not paintable. This is the same thing if you have a large switch with penetrations to the mount. Caulk the back sides well.I have a question regarding distribution blocks and or Polaris multi taps. If I am doing a line side tap via a distribution block and mount it inside a wire raceway or wire trough. How do I waterproof the penetrations when I secure the distribution block through the raceway into the brick wall behind? This is all going to be mounted outdoors and will need to be weather tight.
Youtube comments highlight the video poster in comment sections when they respond to a comment, If Blue is right it certainly sounds like it was a Sol Ark Instruction Install Video that they posted to YT ? IF it was just a comment from the employee that posted the video a grain of salt.I see someone said it, not Sol-Ark saying it. Maybe they did say it, can't say. Means nothing. There is absolutely nothing that points to Sol-Ark being the company who bricked the inverters. If someone can show me differently, I will change my opinion.
I am seeing a few in that range. I am hoping practical preppers drops his price. He already has free shipping which is nice.I am now seeing Sol-Ark 15K prices falling. I think was like $5,400. Anybody else finding low prices now?
It’s straight 18k output. Nothing changes with PV etc which is a good thing. Or at least that’s what their spec sheet shows.I spoke with Sol-Ark and apparently the new 18K inverter will require 4/0 to each set of terminals for full charge and discharge capacity. The physical dimensions are like an inch taller, width is the same. MPPT capacity for PV is increased to like 28 kW. Not certain of the total watt output on battery or battery + PV.
Tommy Brennan sol-ark ceo is responsible.I see someone said it, not Sol-Ark saying it. Maybe they did say it, can't say. Means nothing. There is absolutely nothing that points to Sol-Ark being the company who bricked the inverters. If someone can show me differently, I will change my opinion.
Hi Gland. Also in the spec sheet:The MPPT controllers can accept an input of 36 amps, up from the existing 26 amps. The voltage ranges remain the same. What this means is that the new inverter may require awg 8 wire into the MPPT ports unless the design allows for more parallel inputs to each mppt to add up the amps inside the unit. The manual will be needed to know this.
$.30, about $.13 for electricity itself and the rest in fees.Just out of curiosity. What do you pay for electricity? Last month was one of our cheapest in 4 years at $.142/kwh. It’s been as high as $.17/kwh.
Hopefully they changed those jankey lever lock MPPT inputs to allow for AWG8. The 15k states a max of AWG 10 for its MPPT inputs.The MPPT controllers can accept an input of 36 amps, up from the existing 26 amps. The voltage ranges remain the same. What this means is that the new inverter may require awg 8 wire into the MPPT ports unless the design allows for more parallel inputs to each mppt to add up the amps inside the unit. The manual will be needed to know this.
Guessing they are still using same connections so just have to double up with awg 10Hopefully they changed those jankey lever lock MPPT inputs to allow for AWG8. The 15k states a max of AWG 10 for its MPPT inputs.
It’s unfortunate they did do 4 MPPT inputs. A pair of SRNE ASP would get you 4 MPPT inputs and 2KW more output capacity. AND you’d have almost $5k extra in your pocket by not buying the $7,300 18kGuessing they are still using same connections so just have to double up with awg 10
This is unchanged, just the amps have been increased.Hi Gland. Also in the spec sheet:
No. of MPP Trackers 3
No. of PV Strings per MPPT 2
