DIY spot welder - easy project - make your own battery packs
BarkingSpider
Carbon Lifeform
Silicon Valley, CA
I just completed mine based on a similar system by a guy in the UK. Works great. Handles .15mm zinc no problem.
I used this for the pen and switch ($22)
Amazon.com
This for a secondary switch that I prefer. ($7)
Amazon.com
This relay ($13)
Amazon.com
A small old 300a AGM battery from my garage and some battery cables. (Free)
Makes perfect, strong welds for under $45 and it's fun to use.
Let me know if you need a more detailed wiring diagram.
To get the right duration, I just practiced welding a zinc strip to a large washer. Just a momentary tap on the foot pedal is enough.
I make lots of Lifepo4 batteries in 12/24/48v formats for testing. It's perfect for that.
Its a 300amp 13v pulse. 4000W!
If your want a bigger weld, simply tap again on the same spot.
Its handy, I've been fixing other things around the house with it, tattoo anyone?
Nice to hear some first hand experience!
I'd come across something similar after seeing this video and dreams of DIYing my own house batter ran through my mind.
Amazon.com
Amazon.com
This relay ($13)
Amazon.com
View attachment 29931View attachment 29932View attachment 29933
I got everything put together and working but I am not at all happy with the results. Either I blow a hole in the tab or I don’t get a weld. Is there a preferred thickness of metal strip?
