John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
plug to receptacle.What's p to r?
Backfeeding from p to r means the potentially exposed pins are energized.
That is dangerous.
That wall outlet goes straight to my breaker box and there is nothing else on that circuit. I'm going to take the power going into the wall outlet box, bypass the outlet itself and hook it to AC IN on my MPP for grid connection. The AC OUT on my MPP will then go into that wall outlet box and power the outlet.
I am close to clicking the buy button on this myself, however, do you know if this can be used 100% off grid? I'm going to be powering a standalone shedHere's some info on the MPP LV2424 Hybrid Inverter. It's not perfect, but for the price there's nothing else that comes close to its features. They also make a line of high voltage hybrid inverters for anyone running lots of panels in series.
Thats awesome! I just went ahead and pulled the trigger so hopefully I don't have to wait until July for mineIt arrived, a month early! I just ordered this last week! That $100 shipping charge seems worth it.
I'll have mine hooked up tonight or tomorrow and I should be able to answer definitively then.
That's a sweet looking setup! Can you provide links for the batteries? Also I just checked my shipping status and its scheduled to arrive tomorrow morning?!?
Very cool! I am going to be using this device 100% off the grid. (I could have grid access however, it is quite inconvenient)Got an extra laptop hooked up temporarily. The Solarpower program MPP provides looks pretty decent. The feed to grid from battery and schedule are what I want to tweak. I hope I can set it up to charge the batts from solar and discharge to grid during peak use times. We'll see.
I've run into a stumbling block. Seems the LV2424 isn't capable of feeding the grid from the batteries like their software shows. Their tech support basically said it was a generic manual. Ugh! The whole reason I bought this was to charge my batts by day and feed the grid during peak hours to offset some electric use. Without the ability to feed the grid (my house) from batteries during peak billing it will take 4x as long to recoup my investment. Does anyone have any suggestions?
Regardless of what the marketing information says the operative issue is what your utility and local building department will require. Most likely they will require UL certification and I could find nothing that says this is UL certified. The particular UL certification for grid tie is UL1741. My only suggestion is that you run this standalone as you had originally planned. Be aware of the risks if you are connecting to your permanent wiring without a building permit. This is a good lesson for others if that is any consolation.I've run into a stumbling block. Seems the LV2424 isn't capable of feeding the grid from the batteries like their software shows. Their tech support basically said it was a generic manual. Ugh! The whole reason I bought this was to charge my batts by day and feed the grid during peak hours to offset some electric use. Without the ability to feed the grid (my house) from batteries during peak billing it will take 4x as long to recoup my investment. Does anyone have any suggestions?
You should be able to power a set of outlets like what Will is doing in his solar shed. How are you connecting the AC output from LV2424?
Do you want to send energy back to the poco transformer or do you just want to energise the panel in your house?
Its not really clear from your post.
If its the former then you need to use a poco approved device.
Awesome set up.
Doing something similar but in an RV. I do not need the "feed to grid" option of the MPP LV2424; so I'm looking to get either the PIP2024LV-MK or the PIP2424LV-MSD . Will only be using one Tesla battery and 4x100w panels.
Do you know if the PIP2024LV-MK or PIP2424LV-MSD will work in charging and maintaining the Tesla battery?
Thank you, any information would be very helpful.
