withaview2
- Aug 8, 2022
- 23
Hi! Solar newbie here.
In the early stages in planning and have only the batteries so far. The load (minimum in bold) will be about: 8 indoor and 4 outdoor LED lights. Fridge and freezer. Kitchen appliances. TV and DVD. Battery charging station. Wierless network. Garden water pump. Running electric tools. Fan. Heating cable. Microwave.
EVE 8x280Ah (Lifepo4) cells + 8S 150A JBD BMS.
(24V)
Nominal Voltage 3.2V
Max discharge Current 1C/280A
Max charge Voltage 3.65V
The array will likely be two panels in series with 750W max output.
Longi LR4-60HPH-375M
Nominal capacity 375 Wp
Imp 10.84 A
Vmp 34.6 V
Isc 11.6 A
Voc 41.1V
Temperature rating STC:
Isc +0.048%/C
Voc -0.270%/C
Pmax -0.35%/C
Calculated temperature min -20 Celcius.
The SCC I'm considering is.
MPPsolar (2424MSE1).
(24V)
2.4kv Inverter
105V max PV input.
25A max utility charging.
Do have the numbers on my side or do I need to rethink something, hopefully not everything?
(24V)
Imp 10.84 A
Vmp 34.6 V
Isc 11.6 A
Voc 41.1V
Isc +0.048%/C
Voc -0.270%/C
Pmax -0.35%/C
(24V)
2.4kv Inverter
105V max PV input.
