Play with the graphs and go to the wind chart, put it in annual.
My average wind is about 3.1 mph. You need at least 5.1 to get any usable energy.
Good to see that you took the time to study your site, chose to pass on wind and then take the time to advise others.
My 2 cents is that you really need 12 to 15 mph for any usable energy.
How high is your anemometer by the way?
Rather than bore everyone
again with my background in small wind I'll offer that I have an advanced and very expensive degree in "the perils of small wind".
What is often repeated is that you really need to measure the average wind speed at the proposed hub height. Hub height should be at least 50' above anything within a few hundred yards which quickly eliminates most inland sites outside of Kansas and other plains states. PS. I've installed but thankfully no longer work on any wind turbines in KS.
I couldn't agree more that it's about energy and not power. Below is the AEO (annual energy output) estimate from Bergey for their 10kW Excel that you will have at least $50,000 in by the time you get it installed. $75,000 would be a more likely number.
While it is nice that Bergey offers an AEO you would be wise to assume that it's over stated by at least a factor of 2 and more likely 4x's. That's not just an opinion, that's from personal experience after having installed around 10 of them in areas that ranged from 10mph to 16mph average wind speed. All were on 100' to 120' towers and in open areas (aka: good sites). It was rare for even the best sites to average more than 300 KWH's per month and they never exceeded 1000 kWh's on their best months. Most of them rarely made it past 100kWh's per month. Data logging and wind speed maps put those sites at 10.8 mph or higher. I would love to be proven wrong. To support that, I'll offer $50 per site to anyone that can supply me a link to a unique real-time datalogging site on a Bergey 10 kW wind turbine.
The reason I mention Bergey is because they are often held up as the "gold standard" in small wind. IE: So if anyone can make a great wind turbine it's them, right? From my experience that's completely inaccurate and they are masters of redirecting you to look elsewhere when you start asking why their really expensive machine isn't doing anything near what they claim it will.
Let's pick the middle number of 16,530 kWh's at a 12 mph site. Keep in mind that overstated by at least 2x's. If you spent that same $50k on solar you'd get at least 31,000 kWh's per year. 10 years from now that Bergey turbine will be "dust in the wind" (Bergey themselves will be dust in the wind in just a few years) but the solar will still be cranking out at least 29,000 kWh's/year most likely zero maintenance.
