The MPPT controller is a power converter, taking in the panel power, watts, and converting to a suitable charge voltage for the battery.
MPPT solar controllers are specified for the maximum output current, with units for your power level, 400 watts and a 12v battery, you need a 400/12 = 33 amp unit. ( the actual charge voltage will be in the 13 to 14 volt range so the 33 amps is a maximum)
The controller will have limits on the maximum input voltage and current it can accept. The minimum input voltage from the panels must be higher than battery voltage by around 5 volts for the controller to start.
You have the option of connecting 4 panels in series, or in parallel, or a mix of series and parallel, ( two in series connected in parallel with two in series). The maximum voltage at normal temperatures would be 97.2v, 23.4v, 48.6v respectively. Since at low temperatures the panel volts increase an allowance must be made for that.
Thus is using the 4 panels in series a controller with 150 volt input specification is needed, the parallel and series/parallel options would end a 100 volt controller.
Popular solar controllers are from the Epever range and the Victron range of MPPT controllers.
You have stated a 15 amp fuse, with the panel array options, this series fuse is only needed where the 4 panels are connected in parallel.
a typical setup with 4 panels and a 100 volt input 30 amp solar controller. \this would be the preferred setup for the 4 panel array.
Mike
