mesquito_creek
- Feb 8, 2021
- 146
What could go wrong on a remote inverter that is un attended if I set it to auto start on an over load or over temp fault? It is a MPPSOLAR lv6048. It has ran fault free for about 6 months. Last week it turned off while I was away. The inverter was totally off and blacked out. When I started it back up it showed a fault code 72 "current sharing fault". After a hard start its running fine again.
I leave the inverter on with a residential fridge and 2 RV AC units set at 90 degrees. I have not had any issue to date until now. I am tempted to let the auto start for over load/over temp try to remotely start itself while I am away. The temps are dropping and probably won't run ACs at 90 for much longer...
I monitor the unit remotely with wifi Watch Power so I know when its running or off line. Unfortunately, off line could also mean my wifi router/internet is down and the unit is running fine. But this time it threw a fault and turned off.
