willh
Finally have assembled and started testing 16 230ah cells I got from Docan in the early summer. I assembled the pack in 48v series and let the JK bms do its work above 3.45v per cell. To my surprise it took less than an hour for the cells to get under 0.01v difference while slow charging at 2amps from Multiplus 2. I then discharged the cells fully until low voltage cutoff, based on my rough equipment and math I'm above the advertised 230ahs. I used a kilowatt meter and my dehumidifier running constantly as a load. Kilowatt meter read 11.22kwhs just before low voltage cutoff and this doesn't account for over 24hrs of inverter idle draw advertised at 13w.
My math goes like this:
11220w÷(0.93 Peak Inverter Efficiency)+(26hr x 13w Inverter Draw) = 12402w
12402÷51.2v = 242ah
Obviously not super accurate, anyone see anything totally off with this math? If roughly accurate I'm very confident I got what I paid for atleast.
Second full charge I set bulk to 3.5v/cell and 25amps. The cells were balanced enough that the delta stayed below the 0.01 trigger. The cells seem as if they arrived damn near balanced unless I'm missing something.
Very happy with what I'm seeing so far anyways, batteries shipped direct from China ordered from Amy Zheng at Docan.
12402÷51.2v = 242ah
