So in the not all in one solution but higher voltage there is something like this - https://www.amazon.com/dp/B01MZ53V7H/ref=cm_sw_r_cp_apa_i_cZxvFbM09VQSD
I believe that could be a good basis to a solution combined with a battery charger and an automatic transfer switch. It would certainly be more components but I'm not sure if it would be more efficient. In general I like higher voltages for less line loss and it's overall efficiency but the simplicity of a all in one solution is nice. I wonder if the Eco mode on this system would work with a compressor where the system needs to see power before it cycles on and then would drop to a very low power usage when the compressor is off. I think that would depend on how long you can set the sense duration too and what the low power cut off can be set to.
