does a small 15 amp transfer switch exist?
doox00
US-MI
I want to put a small transfer switch to switch from grid ac or solar ac to the mini split in my solar shed, does something like this exist, a small ~15 amp transfer switch?
US 240v is split phase. isn't it?. Everything posted seems to be single phase
Well, split phase is (almost always) single phase, and the OP has a mini-split, which probably doesn't have a neutral, and the $23 one I found is 3-phase, so you can make pretty much anything work.
Hint: Don't switch the neutral unless you know what you are doing and have a good reason to do so.
