Does disconnecting Inverter under high load damage it?
Turponieminen
Basically i have a setup where timer disconnects negative line (relay) between battery and inverter. Inverter is 2500w pure sine wave and load that gets disconnected is ~1200w.
After relay disconnects there is a high pitched whine coming from the inverter. Does inverter or some components in it get damaged when disconnected this way?
Bob B
Photon Sorcerer
If the inverter has a power switch, just wire a small relay in series series with it instead of shutting off the battery power.
Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Generally it is NOT a good thing to "drop" an inverter hard as the capacitors within have a huge residual charge that will dump to the AC side. I've seen Cheapo Inverters send that out as one big MOFO Spike and fry stuff. By Cheapo, I mean craptastic high frequency junk, you know, the $300 for a 3000W type of junk.
Normal Disconnect for Low Voltage case, would be better. Ideally, IF the Inverter has a relay / switch / control port that can shut it down with a relay signal or put it into "sleep mode" that is ideally the better way to go.
Will has a Video where he uses a Relay to interrupt the ON/OFF Switch externally from a BMS. Something similar could be setup to be more "graceful" and gentler on the Inverter.
I think he had another one but I cannot locate it right now. Sorry.
Turponieminen
Ok. Thank you for this. Inverter does have a power switch and control port for remote panel. I think i will transfer my 12v timer/relay module to control inverter then. I only need to pull 12v from car battery instead of my Lifepo4 battery
Steve_S
That's good that you have two ways to turn off the inverter "politely". Keeping the electronics unstressed and happy rewards itself ;)
