hipringles
- Jan 31, 2021
- 214
For example, the new 15k solark has 200A bypass, but is a ~15kw inverter. If you set PV/Battery as primary source, and your loads are <=15kw, you will use inverter power. But what happens when you hit ~20kw? Will it phase match & mix in with grid, thus 15kw from inverter, and 5kw from grid? Or will it swap over to the grid fully?
I
I
