Does the SPF Growatt 5000 ES Really work the way it's advertises
Jim Lee
Poteau, OK
Is Anyone currently using 1 or more SPF Growatt 5000 ES, or know anyone (that can be contacted for comments) that is already using this system that works the way it is advertised to work? What I mean is, it is connected to their house and it powers the complete house with just PV power during a sunny day and charges batteries so the batteries can assist powering the house during the day and at night and if at any time the PV and batteries cannot produce enough power the Growatt will "PAIR with the Utility to power the load". This system would not use a net meter and never feed back to the Grid. This is a "DIY SOLAR POWER FORUM". Isn't the purpose of this Forum to Trouble shoot Ideas and plans BEFORE We build the system so we don't have to troubleshoot, change out or replace parts after they are purchased, implemented and don't work. Attached is a set of plans (NOT VERIFIED YET) that anyone can use if they want to that we as a group can decide if it should work or make changes such as Wire sizes, fuses, breakers, or whatever is necessary to help insure it will work. Hopefully we can get to a final draft that we are comfortable will work. I plan to build it (I've started the Ground mount already) and we can come up with a plan that anyone can use with a lot of DIY ingenuity and not be a professional Engineer or Electrician.
I'd like to know if it will load share with the utility as well. I would also like to know if if the Growatt 5000ES has back-feeding protection built in if it is connected to the grid when the grid goes down. I don't want to install expensive electrical hardware to isolate from grid down if I don't need to.
The SPF Growatt 5000 ES in an Off grid inverter that can not back feed to the grid and I have come to the conclusion that YES it can pair with the grid. Go to this link and he shows a very short and simple example of it doing just that. No Battery Solar Power System. Growatt Inverter SPF 5000 ES Off Grid Solar.
How does it prevent back-feeding the grid in grid down when it is in load-share mode and the input is connected to the grid? Has anyone simulated this and checked for voltage on the inverter 240 input line? I can't find anything in the manual.
I was told by people smarter than me that as an off grid inverter it can not feed back into the grid when grid is up or down. I haven't put much thought into it because I have a Generac 22Kw whole house backup natural gas generator that I've had for 6 years that has a 200Amp Transfer Switch. When the grid goes down the TS completely physically disconnects from the grid. That's the best I can do to answer your question.
I have 1 set up that works great , I just ordered another 1. PM me and i will be glad to tell you what I know.
Simple. It doesn't allow negative amps at AC-in in both cases.
The only fundamental differences between this and other off-grid inverters is:
1) battery-less operation
2) A power-assist feature that few inverters have (Victron does).
I guess nobody reads this thread. I was interested how the Growatt can load-share with the utility feed and the AC grid input is physically isolated from the grid when the input is 0 volts from the grid.
I can not answer you with absolute certainty. But I believe in the very least electricity flows to the path of least resistance and the inverter will produce only what it can to offset the load. That's if the sharing of a load happens. If the load shuts off the inverter Mosfett will click off. I have 2 of them but haven't set them up yet
See thus YT post on grounding issues with 5000es and the SolarEdge mid-point transformer.
yes I run 10kVA house with 2 spf5000es and 20kWh Lifepo4 and generate up to 50kWh with load management , zero injection too much administration
Did you finish your install?
How has it preformed?
I have most all of the same components already. Why did you decide to go with 2 split phase transformers instead of just 1?
Also I am confused about the new main 200A panel and then 2 sub panels. Can you explain more? Thank you for the diagram. It is very helpful. My husband and I are designing our system and are stuck on the auto transformer and the wiring on a new sub panel. Your diagram is very insightful.
I have one SFP5000es in Brazil (127v) and I'm using similar schema than EchoPapa with difference that i do have some 220v appliances and i power them also straight from the inverter.
And i currently live in EMEA, have two in parallel 10KW like Marbella does. They just work fine. I power the entire house, oven, pool pump, pool heater, fridge, vitroceramic hob and wheel pump. ( forgot a EV Tesla). also a bunch of ACs that i run at night.
The SPF5000ES "can" work paired with the grid (Hybrid mode), but i heard some people saying it might inject some power to the grid and I don't have the contract to do so. So i do not use this mode ever as i don't need it and don't want to risk an issue with electricity company.
ON the batteries, i have two 15ah lifepo4(eve) with Daly bms in parallel. The inverter is battery friendly, you have plenty of options to explore to do automation. Looks very solid and strong.
I'm full off grid since march given plenty of sun here and no issues whatsoever to say. The only one is that is Growatt is not the best company to deal when it comes to customer support etc. As a recommendation to mitigate it -put your equipment on insurance.
K
