Your 40A SCC positive and negative wires should connect to opposite ends of your 3 paralleled batteries to balance charging.Hi I drew how my 400w setup will look like. Should I change anything? Two 100w mono Renogy panels and two mono HQST 100w panels. Renogy 40A Li. 1,000w inverter pure sine wave. Three 120ah LifePO4 batteries in parallel. 12V system
Sorry but when you start two different threads asking the same question things can get confusing. It would have been much better had you bumped your original thread. No I am not the forum police but I am just sayin..... Good luck.Hi I drew how my 400w setup will look like. Should I change anything? Two 100w mono Renogy panels and two mono HQST 100w panels. Renogy 40A Li. 1,000w inverter pure sine wave. Three 120ah LifePO4 batteries in parallel. 12V system
what do you mean when you say " Your 40A SCC positive and negative wires should connect to opposite ends of your 3 paralleled batteries to balance charging. Not to the same end. The same for your Inverter."Your 40A SCC positive and negative wires should connect to opposite ends of your 3 paralleled batteries to balance charging.
Or still better use a positive and negative bus bar off your 3 batteries.
20A fuse is too small.
What gauge wires from SCC to battery and inverter?
Breakers on your 40 foot solar panel wires would be good.
What gauge wire?
I explained in your other thread I am not familiar with solar. I live in an apt. so regarding solar I can't go there because I don't have any experience with it. I did suggest you install a fuse in between your inverter and battery...but that too was in your other thread.I guess Gazoo does not want to help me but thanks for the good wishes.
I understand and I understand your excitement. But when it comes to anything solar I can't help.I have been waiting so long for these LifePO4 batteries and I really want to install everything right.
Put the positive wire from the SCC on battery #1what do you mean when you say " Your 40A SCC positive and negative wires should connect to opposite ends of your 3 paralleled batteries to balance charging. Not to the same end. The same for your Inverter."
