I'm converting a van to a weekender camper and currently have a 120ah agm battery being charged by the vehicle's alternator through a Renogy DCC50s, which can combine (or switch) charging between solar and alternator depending on conditions.
I purchased a portable folding 220w panel from Amazon manufactured by Dokio. When I hook it up to the Renogy charge controller, the controller does not recognize any input from the solar panel. Reading the Renogy manual, it states that it will not charge from solar below 15v. The Dokio is a 12v panel, and testing the panel in full midday sun, it flutuates between 13.8 and 14.6. Seems like most people report more like 18-22v from 12v panels at the source. Dokio states thier panel puts out 13.8v. The cheap charge controller included with the panel also reports 13.8 to 14.6v in the same conditions.
I'm assuming I need to return this panel, but wanted to check with more knowledgable people to make sure I'm not missing something. And if this panel is crap, can anyone recommend a folding portable panel that would output enough voltage? TIA!
