gabriel_navarro
- May 16, 2021
- 2
Hi everyone,
The main reason for this post is that I’m planning to install a V2C Trydan EV charger, which communicates with the Deye inverters. I’m unsure whether I should connect it to the "Smart Load" port or directly to the electrical panel.
Here’s my setup: I have two Deye SUN-5K-SG03LP1-EU inverters connected in parallel on the same phase. The grid cables go directly into the "Grid" port, and all the household loads (the electrical panel) are connected through the "Load" port. According to the Deye manual, everything is connected to "Backup Loads" (I also have a bypass in case I need to isolate the inverters). I don’t have any loads on the grid side ("Home Loads" in the manual), so I haven’t used a CT. I assumed the inverter would manage fine knowing what it’s injecting and pulling from the grid. The system is set to "Zero Export to Load" mode, allowing me to sell power to the grid and draw from it without any issues.
Now, regarding the charger: I’ve read that the AC ports (GRID, LOAD, and GEN) on parallel inverters might have certain limitations in terms of configuration and synchronization. Specifically, I’m not sure if the "Gen Ports" of both inverters can work together when connected to the same charger or if they operate independently. This brings me to my main questions:
Lastly, I have 6 Dyness B3 batteries, and I’m concerned that if I connect the charger directly to the electrical panel (instead of the "Smart Load"), it might draw power from the batteries when there’s no solar surplus. I’ve seen that some people with the same charger mention that it communicates with Deye inverters to determine when to draw power and when not to, and others have chargers with current clamps that can detect if there are solar surpluses. However, my concern is that if I want to charge the car at night using grid power, the inverter might pull from the batteries instead, since, unless I connect it to the "Smart Load" port, it would treat the EV charger as just another household load and supply it with battery power like the rest of the house.
Has anyone experienced this or can recommend the best way to connect the charger to avoid this issue?
Thanks in advance for your help!
- Can I safely connect the EV charger to the "Gen Port" of both inverters at the same time, or would that cause synchronization issues?
- If it’s possible to connect to both, are there specific configurations I should follow to ensure proper functionality?
- If it’s not advisable to connect to both, would it be better to connect the charger to just one inverter? What should I consider for that setup?
