Drok bidirectional voltage current meter and Battery Voltage Monitors/Testers in S Carolina.
Shawn Hayes
Learning Everyday
In A Southerly Direction
Edit UPDATE: Sold one of the new monitors, so only 3 left and Drok hall sensor sold as well.
I have four (4) voltage monitoring/testers typically bought through AliExpress. Three (3) are brand new never opened. I have a 16s wiring harness for each one, all harnesses are 2.0mm spacing interface. However they can monitor up to 24s, but you would need a new wiring harness. They will monitor voltages from .3 up to 9v.
$25 each includes single 16s, 2.0mm wiring harness.
Shipping from S Carolina. Would prefer to only ship to the lower 48 US states.
Message me with questions.
I bought these and then changed my set up mid stream. I ended up buying Batrium BMS, so no longer needs these monitors.
To me these work great for monitoring batteries when doing the initial balancing process with your batteries, depending on what you’re using and how you’re balancing your new batteries. That’s why only one was used and not all four.
If you still have one unopened one and you'll take $30 Paypal Friends and Family Shipped I'll take it. USPS Small Flat Rate Box is $8.50 on Pirate Ship.
Sorry, I have not replied sooner. I saw your message the other day. I got very busy and just forgot about it. I apologize greatly. I still have one of these if you want it.
Where are you located? Inside the US, lower 48?
Total would be $25 and $8.50 shipping:
Total $33.50.
What’s your PayPal?
