After all this time, I still can't wrap my head around when to use and why to use a dual pole (i.e. breaks both + and -) switch or breaker between the PV Array input and charge controller.
I see many people doing this, seemingly regardless of system specifics (grounded, ungrounded, etc). But I've seen guidance that I interpreted to mean a dual pole switch or breaker should be used for an ungrounded array (or system?), and a single pole switch or breaker with a grounded array (or system?). Its possible I was misunderstanding the guidance.
Below is an excerpt from the Victron Smartsolar manual:
Am I misinterpreting what this means?
When should a dual pole switch or breaker be used between PV array and SCC? Are there situations where it is not advised?
* note 1: grounded conductor =/= grounding conductor (green, green/yellow, bare copper wire)
** note 2: "current carrying conductor" = both positive and negative, hot and neutral.
- Provide a means to disconnect all current-carrying conductors of a photovoltaic power source from all other conductors in a building or other structure
- A switch, circuit breaker, or other device, either ac or dc, shall not be installed in a grounded conductor if operation of that switch, circuit breaker, or other device leaves the grounded conductor in an ungrounded state while the system remains energized.
