First, to describe the setup, I have two Sol-Ark 15k inverters set as Primary/Secondary. The 200A grid is supplied to both Sol-Arks via a PDB. Likewise, the load side is combined via a PDB and sent to the 200A main panel in the house (whole house backup). We have 20kWh of Li-Ion batteries paralleled and tied to both Sol-Ark units. Lastly, each Sol-Ark has a string of 8 panels on MPPT1 and a string of 9 panels on MPPT2 for a total of 4 individual strings. All the strings are ground mounted away from anything that might shade them.
I have Solar Assistant gathering data which is fed to Home Assistant via MQTT.
Now the question, I have noticed at various times through the day that the 2 systems do not seem to be equally sharing the load to the house. In some cases, one inverter will actually show a negative wattage. I initially thought that perhaps my Home Assistant was corrupting the data somehow, but I verified the numbers in Solar Assistant and then also with the MySol-Ark website and they all agree.
I've attached a screen grab showing one instance where the house load was around 850 watts. One Sol-Ark was providing 1246 watts to the house and the other showed -355 watts.
This doesn't seem "normal" to me. Can someone confirm if this is expected? If not, any clues where I should start looking to resolve the issue?
Configuration:
Configuration:
- Work Mode = Limited Power to Load
- Solar Sell = Enabled
- Energy Pattern = Load First
- TOU = Disabled
- Max Sell Power = 9000w
