I want to set up a victron inverter charger with solar 12 volt system in a large boat that currently uses two 30amp 110v shore power. The duel inputs feed a split breaker box. One side feeds most of the low amp ac of the boat. The other 30 amp side is mainly for 2 marine air-conditioning units. The boat also has a generator that is isolated from shore power by a switch. I am thinking of at least 800 amp hour batteries and over 1000 watts of solar. To make this even more complicated, I want to use a single or dual isolation transformer to protect the system from shore power issues. I'm open to all ideas?
