@Joe BoyKey ... any chance you can snap a few pics of your inverter install and how you laid out the switchgear at the inverter?
I'm trying to decide if I need / want a breaker in between the battery bank and the inverter. Seems it would need to be at least 200 amps? But finding one seems to be a challenge. Midnite Solar has a DC 250amp, but not finding a suitable housing. I am actually considering just buying a Midnite E-Panel for the Conext SW and modifying to work with the Growatt 12kw. But $450ish
Also, curious, what size battery cable are you using to attach the 12kw to the battery bank? I'm thinking 4/0 (0000)
And what size AC wire are you using to make the connection from the 12kw to the load panel. I was thinking 6awg if it will fit under the screw terminals of the 12kw. I will be setting it up 240vac Split phase.
