Is it ok to fill the gap with more wire ? A cleaner job than this. This was to see if it could be pulled apart with 2 pairs of pliers. It's solid but otherwise it's presses out the sides and looks like @ss. If I can't fill the space with more wire I'll order Ancor terminals that will wit but they won't be closed end lugs. Opinions accepted. Running less than 12 amps through these. If that matters. Thanks.
