12VoltInstalls
life passes by too quickly to not live in freedom
eventually converting to a 48 volt inverter, but that is down the road.
@GregN5XO This is the reason increasing series and going 48 volts makes sense now because you will improve your nominal potential by double. Round numbers anyway60 amp rating is amps going into the battery. 16panels x 200watts = 3200watts.. 3200watts = 133amps @ 24 volts going into the battery.
