I recently tore down 10 DumFume 300Ah 200A Batteries. Made 2 48v packs with matching cells.
Results below
1x - EVE LF280K 280Ah (299AH)
1x - Envision AESC 305Ah
11x - Trina Storage 314Ah (338AH)
1x - Cornex 314Ah (229AH)
QR codes: (If someone can figure out what the 314Ah Cells are that would be great information to have)
EVE LF280K 280Ah
Capacity Test: 299Ah
AESC 305Ah
Capacity Test: Pending
Trina Storage 314Ah
Capacity Test: 338Ah
Cornex 314Ah
Capacity Test: 329Ah
The LF280K 280Ah and AESC 305Ah Both had the following BMS. (Has a finned heatsink. A rather large one.) Temp sensor could be a switch?
All of the 314Ah Packs had the following BMS (Same exact size as the above, but the heatsink is flat with no fins.) Looks like it has a normal non switched temp sensor?
Results below
EVE LF280K 280Ah
AESC 305Ah
Trina Storage 314Ah
Cornex 314Ah
