dude47
I purchased 4 of these on temu. Looking at the dimensions , specs and physical appearance I believed they were likely a relabel of the Wattcycle brand batteries 300mini (280ah). I figured the manufacture was likely trying to offload some of them under some under another name. With temu's super coupons (if you have ordered from them they have this really cheesy deal where if you make purchases they give you coupons to make more purchases) the cost I paid for all 4 was $850 OTD with two purchases with $150 off $500 coupons.
They arrived today and I couldn't help myself, after I got the kids dinner I had to pop one open. Lots of glue, after 30 minutes of prying I was able to get the lid off intact. What I found was a massive surprise as I was expecting 280ah cells like the Wattcycle, thinking if I got lucky I maybe would have the 300ah cells like labeled. I found neither....
314ah Eve cells...
I am flabbergasted... Maybe they are Grade B? How can I tell?
They shoehorned these cells in the case. Only foam block is on one side with the BMS and the top. The bottom, sides(thin pad), and back of the cell packs rest against the case firmly. I will charge one tomorrow when I get home from work and do a capacity check.
@Will Prowse Have you ever seen cells with higher capacity than what the manufacture labels?
Can anyone ID the BMS? It has a nice sized heatsink on the back of it.
314ah Eve cells...
