Not sure if I'm in step with the thread about this but I remember seeing Engineer775 on YouTube show where they hooked the bottom thermostat to a Sol-Ark's smart load (which is excess power once everything else like batteries, loads, etc have been covered), and the top thermostat to the homes main service panel like normal. That way he was getting solar to heat the water, and grid power for the top thermostat which I understand is the recovery element if/when you need to heat water fast. The bottom element is what heats 90% of the water in the tank and is slower to heat since its more water on it (its near the bottom of tank). So, you're heating most of water with solar power, and you have the top element to take you the rest of the way depending on how much water you need or are using. I think bottom element is 120v and top element is 120v. Thats why without solar you have to run 240v to a water heater. No need to change it thermostats, just make sure you are running AC power from the inverter to the lower element. And AC power from your main service panel to the top element. As stated already, and a reminder, do not put DC power to a AC thermostat, it'll burn out almost immediately. I thought I'd mention the idea of practice of sending inverter power to bottom element, and grid power to top element. To me that seems like a good balance.
