Hi Mike,
Thank you very much for you detailed response; it does very much help!
I have done a great deal of research, I am generally good at digging out what I am searching for even if the knowledge/information is sometimes obscured or dispersed. But fully detailed use cases are hard to come by, so thank you very much for yours. What you write above touches on pretty much everything I have been able to synthesize from a great many resources and forum posts. I had come to the conclusion that it is, as you detail, paramount to be generous with your panel wattage. This is only becoming easier as $/w goes down with better and better panels. Failure to consistently fully charge is to fail. Your specific experience is a very welcome data-set that backs up what I had come to understand in bits and pieces - both from failure use cases and success use cases around the web.
It is very interesting that you have gotten above 3000 cycles with 50% DOD. That is very strong performance. That comes close to rivaling the published performance (accelerated ageing) for Trojan IND line! Nothing short of impressive and exciting. (given that people could be skeptical of such performance I want to emphasize my statement is genuine, not sarcastic). Makes you wonder what those high quality batteries could do in the hands of the right person.
Note taken of your EQ regime, you must be doing the right things throughout.
I agree on your take on the specs I listed, it makes no sense. How could they possibly have come to that conclusion? But as an engineer I am all for putting all information available on the table so what needs to be discredited can. I don't think I can post a link, but if you search in google, copy this Sam's Club/Deka/Duracell/EastPenn 6V GC2 specs and your first search result should link you to a forum post in forestriverRV forum that contain a link to the spec as published. Your data invalidates this, but for completeness/interest it's there to see.
It gets all the more impressive with the temperature you have recorded. That is supposed to significantly shorten life expectancy; yet you got 8 plus years. On top of this you have two parallel strings! Have you ever had any negative effects of the parallel setup?
I feel the need to ask but with the lifespan I imagine no.
Your advice for proper care is very straightforward and could not be stated simpler. How would this be too much work compared to programming and managing BMS lithium setups?
Have you considered/used automatic watering? Or is it in your opinion not worth the expense for a perhaps pretty easy/not too frequent task?
Yes, lithium is all the buzz. It is exciting. New technology is a promising thing and I have nothing against it. It is unfortunate though that excitement tends to run ahead of thoroughness and impartial investigation. I think a big missing link in the DIY sphere is giving Lead-Acid a fresh look, what can it do today rather that judge it on preconceived notion. If LA were treated with the same innovation/craftiness and vigor as is homebuilt Li packs, where would LA stand? I don't mean build your own LA battery, but more in the realm of how can we extract better performance. I tend to be the type that notices what gets missed so hence my interest in what can LA really do.
Thank you
Carl
Hi, Carl...
You bring to the table many good ideas and questions.
Set your wayback machine to 1983, and the cost of a 35 W solar panel was around $600. I don't know what that would cost in today's money, but let me tell you, I was selling PV back in '83 and $600 was a whale of a lot of money. For your $600 bucks, you got one solar panel that did about 2 A. The popular, at the time, ARCO 16-2000 did just that—16 V at 2000 mA—thus its name.
Even if you had the money and purchased four to six of those panels, you were only able to squirt in 8/12A on a good day. Now, you're charging a set of two golf cart batteries that you're sucking dry every night or so. Twelve amps won't do you much good and after a year or if you're lucky, two, those batteries were toast.
Now you have to also remember that the price of lead acid batteries in '83 were dirt cheap! A trojan T-105 hit you for forty and change!
Back then, only the super rich could afford enough solar to keep a set of LA golf cart batteries fully charged and healthy. Up until let's say five/eight years ago, the price of PV panels were still damn awful expensive.
Now, returning to the present, I should clarify that during times of low solar, I didn't discharge the batteries too deeply. If I had a week of rain/snow, I disconnected the load and let the batteries float on whatever was coming in from the array.
With the price of PV dropping like a rock, you can get used panels from Santan Solar for less than $40 a panel now, unless you don't have the space, you can add enough solar to your setup to keep those batteries fully charged.
My wife and I are still on the grid, and we use a 10kWp grid tie along with 7kWp of battery off grid. Around end of February, I go off grid and on the batteries until the weather changes for crap sometime in october. Then I watch the state of charge and the depth of discharge and go back onto the gird as needed.
My current utility charges me $.06 per kWh and the batteries cost my $5600. Kill the batteries or pay Ohio Edison $.06? Hummm... what to do?
If I had a setup of dozens of batteries, then I'd consider an automatic watering system. Too many wrenches in the machine certainly increases the chance of something going wrong.
Personally, I enjoy working with the batteries and make it a point to check water levels every two weeks. I do one check before I equalize and one after equalization.
Temperature is the one factor that I see as a issue with Lithium batteries. They simply don't like to get cold. To me, it seems to be self defeating to use their own energy to keep them warm (via heat tape, blankets or what nots.)
And I can't argue that Lithium batteries are superior in many ways. However that being said, the price point is still outside for most of us. My 25kWh worth of lead acid storage (the 50% DOD already figured in) cost me $5600. To get that much storage in a lithium setup would push the price to around $30K. That's not reasonable by anyone's measure. Especially considering the price I pay for gird power is $.06 a kWh.
Chinese cells for a third of that? I guess so. Lots of people are doing that. At this time, I'm seeing the light at the end of my tunnel, I'm working on other solar electric projects.
Mike
