DYI off grid with Bluetti feedback appreciated
WCC
Colorado
Hello
So my house has a transfer switch installed to the main panel and the panel has a generator interlock switch installed.
My plan is to go totally off grid and to store my own power. And here is my equipment.
- Two Bluetti AC500 inverters with fusion box (240V/10KW Split Phase System)
- Three to Four BC300S Batteries (9-12kW)
- Nine 345w Solar Panels (ground array)
Once everything is complete I would connect the fusion box to the transfer switch via cable. At the main panel I would utilize the generator interlock switch to disconnect from the utility company and switch over to the solar generator system for whole house power.
Thoughts???
You need a power audit to determine system size requirements, is your range, hot water, dryer ng or lpg do you have a well pump or city water these items are heavy loads requiring large systems
That’s 55 kw a day you must be all electric heat water ect your not going to do that with the bluettis 55 kw is a large system!!
