reecetas7196
- Dec 6, 2021
- 21
This may be a dumb question, but could I use two 100w panels for the 202ah lifepo bank? Wouldn't it just take longer to recharge?
YesThis may be a dumb question, but could I use two 100w panels for the 202ah lifepo bank? Wouldn't it just take longer to recharge?
Longer to recharge, or never recharge, it depends on your consumption more than your battery bank size.This may be a dumb question, but could I use two 100w panels for the 202ah lifepo bank? Wouldn't it just take longer to recharge?
Watt hours is also divorced from system voltage which I don't think is a settled issue yet.If we talk just in Watts and Watt-hours the math is much more clear
Something like the Victron Smartsolar 75/15 would do the trick.What would you all recommend for a charge controller for two of these?
urge you not to buy components or even kick tires until you have defined your requirements.
No, you didn't miss it. I've done my calculations of planned loads. I did not post. I'm just piecing together the system, yes. Not the best practice, but when you're on a hardcore budget, you'll do what you gotta do. I'm building out a mercedes sprinter van. It's a 2002 e150 conversion van high top. I'm just trying to piece a working system together. Currently, I have my 100ah 12v lifepo4 battery and two 100w solar panels that I may eventually add two more for a total of 400w. I asked about the charge controller because I want one that is a good fit for the two SP's I have and one that will support me adding two more down the road. Nothing is wired, I'm just piecing it all together and will wire it all up sometime soon down the road.What is it you plan on running with your system is what he’s saying.
I’ve been reading along. While the questions of will this X and that Y work can be answered narrowly, not only is it very random it doesn’t answer the most important question of, “will this meet my needs?”
Did I miss where your planned loads were listed?
400W / 12.8V = 31.2A max charge capability100ah 12v lifepo4 battery and two 100w solar panels that I may eventually add two more for a total of 400w.
Got links for the panel and charge convertor and whatever else I'd need for for those type of panels?What van are you converting? I put one commercial grade 465 watt panel on my minivan. That's much better than 4 of those China made hobby level panels.
You can find the overkill BMS on eBay for a better deal. Get one with lugs, not with soldered wires.
I hear that. Been there!when your on a hardcore budget, you'll do what you gotta do.
Although a bit more money Victron is a top shelf brand. It should last well.Configuring 4 panels in a 2S2P manner (quite popular), you could get by with a Victron 100/30
I'm in California. This is just a diagram I found online. I have two 100w Solar Panels and a 100ah Lifepo battery. That's all I have right now. I need to figure out what I need to get a basic solar setup with a Fuse box to include my LED lights and MaxxFan for now. Also, eventually an inverter, probably 2000w. and the switch and whatever else is needed for switching between car battery charge and solar charge for house battery.Should be over-current protection between the starter battery and the kill switch
Also 10 awg undersized for that long circuit and will cause excessive voltage drop
There is no provision for shore power
We usually like to see a double pole single throw switch between the panels and the solar charge controller
That 100amp hour agm battery would not even run that inverter for 30 minutes at full bore.
Its a very small system by today's standards
Are you in North America or other?
A 2000 watt inverter will draw...I'm in California. This is just a diagram I found online. I have two 100w Solar Panels and a 100ah Lifepo battery. That's all I have right now. I need to figure out what I need to get a basic solar setup with a Fuse box to include my LED lights and MaxxFan for now. Also, eventually an inverter, probably 2000w. and the switch and whatever else is needed for switching between car battery charge and solar charge for house battery.
