Repro
I ordered the East Tester ET 5410 and it arrived in two days. I was super surprised as it is has long delivery times right now. I put it to the test last night on a battery I recently purchased to verify my previous testing. I also have a smart shunt with data logging, and it always seemed to have differing results that were most times far off those of my old load tester. So I decided to get this.
My results between this load tester and my smart shunt were much much closer. So close that they were off by 1Ah on the capacity test. I am happy as I feel that I now have accurate testing. The tester is really easy to use once you understand the navigation. That took about 30 minutes to get used to the interface and menu's. It has a wide range of selectable measurements, and testing modes that go beyond the scope of my knowledge.
It is well built and very solid. It doesn't come with any testing leads, so be prepared to make your own. It can provide loads up to 40A, and this drastically shortens test time on batteries with big capacities. The color display is big easy to read. It is solid and well built. if you are looking for a load tester, just take a look this one, and do more research on others as well. This one was priced so that I could afford it, and it performs well. I hope this helps someone looking for a load tester.
By the way, I am happy to announce that my new battery has surpassed its rated capacity
