Hello everybody, i have some issues with my Easun SMG II 3.6KW 24V Hybrid inverter, if i connect chassis earth to home earth, everytime when i switch off power from grid and then reconnect it again to grid I get a 08 error , and inverter switch off ac output and then comes back to normal after around 1 minute. But if I disconnect the chassis earth from home earth everything works normal with no errors, no matter how many times I switch off and on connection with the grid! I tried as well to connect chassis earth of inverter with another earth rod from garden, separated from house earth, but same thing happens! Anyone knows what could be wrong here, because this is giving me headaches! Thank you!
