I recieved the MPP 2724 from Taiwan earlier this week, and two roll-up flexible solar panels from Battery Hookup, and been playing with these using a small 24 v (18650 DIY battery 8S-5P) just for testing the operation. {Note: I have ordered 8 Cells 280Ahr and a JK 100A BMS to build a larger capacity battery but cells are not in yet}. I have some hand held tools I use at the cabin (to do general work on the place) these include a 3/8" corded drill and a 6Amp corded jigsaw for cutting pine T&G interior pieces. {I don't use battery tools at the cabin, no easy way to charge them, and they would be left unattended all winter, not good).
So the first test: hooked up the small 24Vdc battery and fired up the MPP 2724 - all good. Plugged the PV in (the 2724 has MC-4 connections right on the unit) and it started charging the battery.
I clamped a DC Volt meter to the battery leads (the MPP came with a nice set of leads that plug right into the unit and end in ring terminals ready for the battery) I wanted to be able to see what the battery voltage draw down was with the tools running. Unloaded the voltage was 27.6VDC
Plugged in the drill and ran a few holes with a large spade bit through some scrap 2x6 on the bench - all good. Voltage on the meter dipped to 27.2VDC and the MPP display showed "20%" on the output on start up for about a second, then dropped down to 10% running the drill steady.
Plugged in the jigsaw and cut some of the 2x6 and leaned into it to push the amperage cutting through knots. The volt meter dropped to 26.8 VDC and the MPP display on starting the saw hit 50% for a second then dropped to 25% cutting steady.
Having the plugs right on the MPP is a super bonus, as it literally took five minutes to connect a battery and PV to the built in MC-4 connectors and was up & running. Well, next step is to test it at the cabin to see if my well pump is 'a go' or will it be a 'no-go' on the small inverter!
I will let everyone know!
Robert.
