eco flow use questions.
papa masaitis
milton fla
Got a eco flow set up, consisting of 2 Eco flo pros as well as 4 smart batteries, I have been using as a backup, by switching back and forth, I have a 240 hub on hand, however I want to just connect the whole system together to equal 21,600 watts. Only want to use 110volts as my back up(only). So I dont have to keep changing the 30amp plug back and forth. Does any one have any ideas. Thanks
Unless I am misunderstanding something, why can you not just connect your smart batteries (2 each to 1 DP), then connect each DP to the 240 volt hub, then plus in the 30amp plug into that and the other end into whatever you were already plugging that into before?
