I recently picked up an EcoWorthy 300Ah LiFePO4 battery and I’m running into some cell balancing issues that I could use some help with.
The problem:
My setup:
Questions I’m trying to figure out:
Any help will be appreciated I need to use these battery tomorrow.
The problem:
- When I charge the battery to 100%, some cells go higher than others instead of staying even.
- I’ve noticed the BMS isn’t doing a great job keeping them balanced at the top end.
- Below ~13.5V things look more even, but near full charge, the imbalance shows up.
My setup:
- EcoWorthy 12V 300Ah LiFePO4 battery (with the stock BMS).
- NOCO Genius 10 charger (only 10A).
- Is this normal behavior with EcoWorthy batteries, or is mine defective?
- Does the stock BMS even balance actively, or only passively at a very low current?
- Would using a higher-amp LiFePO4 charger help with top-balancing? If so, what chargers are recommended?
- Has anyone tried updating/replacing the EcoWorthy BMS?
- Would adding an external active balancer be the best solution here? Any specific models you’d recommend?
