Won't work if you are using the RS232 jack. You are limited to 15 (might be 16 but address 0 is not used so...) batteries connected via the cat5 battery to battery jacks. The EW Software connected to the Master (using the RS232 jack) should see all batteries as will SA.
I have not tried the RS485-1 jack on the Master to the EW software. Should be easy to test to see if the EW software sees all batteries from a single connection to the Master. I suspect not as many have had to resort to multiple RS485 converters.
The JBD appears to operate the same as a PACE BMS. You can read all the relevant battery data from the Master RS232 port for any battery but you cannot set any parameters for batteries other than the one you are connected to on the RS232 jack. Same issue Andy's Garage points out with the PACE BMS. However the PACE BMS software (PbmsTools) will set the parameters FOR ALL batteries at the same time. Minor inconvenience as all batterie should have the same parameter settings.
The issue here is single point monitoring which I hope works for all the folks that have multiple EW Batteries. This was the main issue I had at the very early and beginning of this thread and I believe it has been corrected by EW, at least my testing and my software confirm that I do with my tow batteries have single point monitoring capability.
If for example you want SA to display a different Serial Number for each battery than you would have to connect to each batteries RS232 jack, select the "Config" tab and change the "SN Code" (default JBD48100000) to what you want SA to display. Once that is done (
@jorby has a lot of batteries to shift to) SA will display that data. The "SN Code" is read from each battery via the Master RS232 port whereas the "BMS SN Code" and "Bar Code" require physical connection to the specific battery
