@Gavin Stone did a pretty good review but there was a few things that we discovered here.
He did a very nice video. I guess I missed my chance at the big YouTube cash cow back a few years ago. Fishing, Diving, Hunting, and Technology. What's not to love.
Others please add/correct to my list:
BMS is JBD UP16C019A with Wi-Fi and Bluetooth.
Pre-Charge is a PWM when the BMS turns on so no resistor but does the same thing
Didn't mention that it will do all the other protocols if you change it via windows software. I believe the E-W app will also do it.
It does have be cycled a few times and held at top to get the balance correct, negative there The Capacity is set by BMS so if you open it up say 110A it will give you more but he had a cell trigger UV. This is where my procedure with the Active Balancer on every new welded cell battery is priceless.
You can read a lot of the settings with the OverKill app but it only writes some variables. It isn't completely compatible.
Now on the discharge test. The battery cuts you off at 80% or at LV of cell or pack. So when I did
mine here my results were between the 96 to 100A. Now would that be considered only the 80% level. If we would have taken it down another 20% to zero (bypassing protections) wouldn't it been closer to 120A?
The New UL Listed battery hopefully by May 2025 should have rapid shutdown and fire arrestor.
New 6 rack should be a available soon. There are no busbars. The cables connect the batteries on the outside terminals.
