Eco-worthy 48V 60A Battery Charger: 3.5KW Max Power
It might require changing the control board.
It’s an easy fix but a bit costly for EW.
Not trying to derail the thread, but wanted to chime in to say my EW charger is set to 24h on timer1, 0 on timer2 and timer3, and has no problem pushing 60a to my batteries. Im using grid, not generator, to provide 240VAC power to the charger, which might make a difference.
Same here.
Crowz, is the only one having that issue. As far as I know.
The adapter that came with it won't work, in any situation.
My Craftsman generator has two plugs on it (other than the standard three prong house outlet) and they are the one on the charger and the one on the end of the adapter. You saying that if my generator had just the three prong outlet that the adapter that comes with it could not be used?
That's correct.
Well the adapter arrived and worked perfectly.
I ran the charger from 11am to 5pm flawlessly.
That said I did have to set it to 23hr on the timer to get it to charge. It defaulted to 24hr and with it set to that it wouldn't start charging.
I would push the on/off and it would switch to showing auto and then flip back to manual without starting to charge.
I changed timer 1 to 23hr and it started charging.
Weird.
Anyways it charged fine at 60 amps the whole time after that. Never got hot either. The 2 ga wires I swapped out were cool to the touch so that upgrade worked great :)
I doubt I will run the generator near as much now. It cost $3 and something per gallon here for super unleaded (its used in the mowers and cars when the kids forget to fill up, etc) which normally works out to burning 4 gallons when I run the generator. So $12+ a run.
The grid's power cost me 1 cent per minute to run the thing. So 60 cents an hour. So 4 hours $2.40 which makes it much cheaper.
That's correct.
What would happen if I or some else did use it?
Would it do nothing, or it blow/burn something up?
Which end is wired incorrectly?
I am thinking of replacing the 3-prong end of the provided adapter with a plug like my dryer or is the 4-prong end the one that is not wired correctly. Might be better just to by one already made.
Nothing
Neither, it's exactly how it should be, for what it's supposed to do.
There are no legally available adapters that switch a hot to a neutral.
That wouldn't work.
Yes
That wouldn't work.
Yes
Except there is no such thing. Either make your own after understanding the details, and tag it as for that specific use only (tie-wrap it to the charger cord?) or change the end on the charger cord for your one true use.
Dryer to Charger?
This is what I was thinking about.
That wouldn't work.
Yes
Any chance someone with a chargeverter too that will try having both connected to the same power source and see what results you get?
Both work fine.
Connected to the same circuit, from my system.
I'm sure that your issue is generator related.
Can't find a great explanation.
But it looks like....
Timer #1 turns it on.
Timer #2 turns it off.
And Timer #3 turns it on again.
Not sure what the reasoning is behind them.
