Price is correct but that's out of China, before ddp.The price has to be wrong too. They charge that for a lot smaller battery.
I asked about a 14kwh a while ago. DDP was $900 each!Price is correct but that's out of China, before ddp.
There are no handles.. I looked at some other big roller batteries and I do like the E-W handles on the top corners the best. It makes it easy to control it as I roll it over my cracked driveway
*Weight:380Kgs (net weight 252kgs)There are no handles.. I looked at some other big roller batteries and I do like the E-W handles on the top corners the best. It makes it easy to control it as I roll it over my cracked driveway![]()
"Price doesn't include hernia operation"*Weight:380Kgs (net weight 252kgs)
*Size:720*435*1100mm (Package size:785*500*1100mm)
I think we are beyond the capabilities of even two grown men.
More than one seller as far as I can tell.Oh I see it I had given up earlier.
Still too risky for me with this recent negative feedback
Edited to add: this is feedback from the s power battery seller robby linked to, not the ecoworthy battery.
Agree,For the price, why not just buy a couple more server rack batteries.
Is that a bubble or a crack in the top left corner of the screen?It slow charged all day today. It came up to the defined capacity. I discharged it slightly and then put it on the lowest current I could that would register in the software 0.58A with a differential of 54mV.
I'll put it on the Cement Pond Dummy Load one more time tonight.
It is either a hair or the plastic screen cover. I have been pressing a lot of buttonsIs that a bubble or a crack in the top left corner of the screen?
Probably easily replaceable if the latter.
So discharge #3
I am done cycling, getting the itch to crack this egg openSounds like a weekend plan.
Maybe time to add active balancing to the feature list for 280Ah v2 or v3?I put all the settings back to factory default. No question about the capacity.
More cycling and balancing required. Looks like the barracuda bobster top balance method is required. Any suggestions?
We all know that a five amp active balancer would solve this.Maybe time to add active balancing to the feature list for 280Ah v2 or v3?
Exactly, same with the 5kWh rack mounts. They deliver rated capacity without faffing around. From what I recall they had mentioned better battery matching coming online so cell deviation should be even less going forward.Looks like it delivers full capacity. Futzing around with balancing now is looking for problems that don't exist.
Good points and likely accurate for the average buyer. I don't think @BarracudaBob will be satisfied until it's balanced.Exactly, same with the 5kWh rack mounts. They deliver rated capacity without faffing around. From what I recall they had mentioned better battery matching coming online so cell deviation should be even less going forward.
I disagree cuz all my batteries can go up to 56.6 volts at least once a week to top balance this thing would never make it past upper 55 volt range and always going to alarm.Looks like it delivers full capacity. Futzing around with balancing now is looking for problems that don't exist.
