I'm fairly new to electrical systems. I'm using an EcoFlow Delta Pro to power my camper van's electrical system. The AC output is connected to a Blue Sea 120V panel through the Delta Pro's 30A plug, with a ground-neutral bonding plug in place to ensure GFCI outlets function properly. At the same time, I'm charging the Delta Pro via the solar input, which is connected to a 48V battery grounded to the van chassis. Could this setup create a ground loop?
