packdaddyapp
I’m stuck in analysis paralysis. Lots of info out there and am trying to neck it down to what applies.
I have an EcoFlow Delta Pro and a non-inverter gas generator (https://westinghouseoutdoorpower.com/products/wgen9500df-generator-dual-fuel). Adding solar panels is on the future-projects list.
COA 1: In extended power outages, can I charge my Delta Pro with the generator I have (link above)? What are the risks of using a non-inverter generator to do that?
COA 2: Should spend $1k for the EcoFlow Smart Generator? Is a $600 harbor freight inverter generator just as good? I don’t necessarily need the “smart” features of EF’s.
COA3: Can an EG4 Chargeverter be used with my current generator to charge a delta pro? I couldn’t tell from the manual what the output cables are like (typical battery cables or can you make the output a NEMA connector?).
I appreciate any advice you smarter-than-me people could provide!
-Patrick
-Patrick
