Hi all,
the EcoFlow Delta Pro's Anderson port should have up to 378W output power (12,6V DC, 30A), according to the specs. So I was thinking it might be worth to use it for powering low loads instead of using the integrated inverter (which has a high self-consumption of 40-50W and a sub-par efficiency for < 100W loads).
I bought a Victron Phoenix 12V/375W inverter, connected it to the Anderson port and actually expected it to work just fine within that low power range (<100W)
However, as I experienced the opposite is the case. The power delivery is very unreliable and often fails to power even lightest loads (<10W), the DP bailing out with "Overload 217", then you have to switch off the inverter and the DC output and try again. On the other hand, it sometimes also works just fine for 50W loads for an extended period (30+ minutes). The DC cabling to the inverter is 10AWG.
Is the Anderson port's output circuit just crap or what may I be doing wrong here? And what are your experiences with the DC output on the Delta Pro, does it meet the specs at least when used with native DC consumers?
