EcoFlow Delta with Jinko 385W Solar Panel
Wanting to pare the EcoFlow Delta 1260W solar generator with a Jinko 385W solar panel (VOC 49.1V, 9.44A). Will they pare well together? The Jinko solar panel is a used commerical panel and I wasn't sure if I'm over looking a key issue. Thought it would be a good idea to just put 1 panel on the roof of the vehicle in lieu of fitting 3 and yet still get max watts. Thanks for commenting.
Your answer is what's the Max Volts input on your Ecoflow Delta? Specs?
